Hi,
I’m looking to use NZBDrone’s API to create a (Rainmeter) skin which shows future shows to be downloaded (and maybe already downloaded shows) that updates automatically. (Rainmeter simply parses data from the API output using a URL)
I’m having some trouble getting my head around the API though.
So far I got this
http://192.168.0.13:8989/api/calendar?apikey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
which works but only returns shows airing today and tomorrow.
What I am looking for is an API command which return all shows airing in the next 1-2 months (a long term view)
I’ve tried adding this to get me starting in the right direction
http://192.168.0.13:8989/api/calendar?start=2014-10-14T22%3A00%3A00.000Z&end=2014-12-31T22%3A00%3A00.000Z?apikey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
start and end syntax taken from another forum post but this displays the ole Authentication required for username and password which I have none set up (also tried setting one up but no luck still)
Have tried many different syntax but not getting the results I’d like.
Any help would be appreciated, thanks in advance…also AWESOME program!
