Both Indexers Dead
Only started seeing this today with raring, KAT seems to be down too, so basically that’s my install out of commission. Any likeliness this has anything to do with the update & shift from httpClient?
NzbDrone.Core.Indexers.Exceptions.IndexerException: Indexer API call returned error 1: No token set!
at NzbDrone.Core.Indexers.Rarbg.RarbgParser.ParseResponse (NzbDrone.Core.Indexers.IndexerResponse indexerResponse) [0x000bc] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Indexers\Rarbg\RarbgParser.cs:40
at NzbDrone.Core.Indexers.HttpIndexerBase1[TSettings].FetchPage (NzbDrone.Core.Indexers.IndexerRequest request, IParseIndexerResponse parser) [0x00008] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Indexers\HttpIndexerBase.cs:273 at NzbDrone.Core.Indexers.HttpIndexerBase1[TSettings].FetchReleases (NzbDrone.Core.Indexers.IndexerPageableRequestChain pageableRequestChain, Boolean isRecent) [0x0009b] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Indexers\HttpIndexerBase.cs:142
Incidental it seems.
I tried changing KAT from http to https (which at some point I’d changed due to it not working), it works now.
Automation resumed.
RARBG is still appearing to be problematic, but I’m likely to believe iy may be their end.
Tried with same tactic:
https://torrentapi.org/pubapi_v2.php
Unable to connect to indexer, check the log for more details
http://torrentapi.org/pubapi_v2.php
Unable to connect to indexer. Indexer API call returned error 1: No token set!
Originally (yesterday), http://torrentapi.org/ worked.
Will give it a day or two to see what happens.
Fixed rarbg on .3970 develop. tnx for reporting.
