Sonarr version (exact version): 2.0.0.4146 Mono version (if Sonarr is not running on Windows): OS: Windows 7 ( client windows 10) ((Debug logs)) (posted to hastebin or similar): will add Description of issue:
noticed tonight that a single episode was repeatedly downloaded via SAB. Completed download handling is enabled, where the download fails on SAB, is the removed from SAB, and then searched again after which it is added again.
only issue is, it is adding similarly named NZB’s form the same provider which i dont believe is correct operation
Multiple indexers may report different posting times due to differences in the providers they use or in some cases whether they use the time they picked it up vs the actual posting time. Size can vary due to different files they pick up and whether there are par2 files. The settings are fairly relaxed, but do err on the side of getting the release, even though that may take a few tries.
If you’re getting failures on recently posted content the issue is likely propagation and setting a minimum age for usenet releases would help the most instead of hoping to eventually grab something that was just posted and propagated properly.
