Blackhole issue
Hi all, just installed NZBDrone to try. I’ve got as far as selecting my download, my plan being to use the watch folder feature of SABnzb. For some reason, I can’t get a valid path to either my download or watch folder. I’m using \home\seeder\files\sabnzb\complete\ and all versions of it. Any ideas?
Why would you use the watchfolder?
Isn’t it much better to use the Sabnzbd api? Blackhole a measure of last resort.
As for the path, are you sure the nzbdrone user has permissions to access the path?
Well, I worked out the path issue. I was using / not \
If SABnzb is better, I will use that. Other than setting up how to access SAB, is there anything else I need to add or setup, maybe within SAB?
Just a category specific for drone.
Well, I tried adding my SAB details but it fails with “Test was aborted due to an error: Object reference not set to an instance of an object”
Now, I also can’t seem to get Mono past 3.0.6 on my Debian system so is that causing the error?
