Issue:
I have found most torrent clients can’t handle more than a few hundred torrents at a time without locking up systems.
Currently it allows you to enable more than one client however doesn’t seem to ever use the second one. Even when first client fails.
Solutions:
Enable by days of the week - Where you can set certain clients to be to be set as enabled / disabled automatically based on which day of the week it is.
Disable once X number of torrents - Disable a client if it has X number of active torrents
Disable if error - Disable client for X time or until manually reenabled if client becomes un responsive.
