I have been enjoying Sonarr for quite a bit now and its really chill.
All though i got a question, lets say the walking dead.
I have some 720p and some 1080p quality episodes in there.
Can I make sonarr download 1080p and if it doesnt exist fall back to 720p?
Edit: can i mass rename all episode files to remove the add the serie name?
You’ll need to setup a Profile that accepts 1080p and 720p releases and set the cutoff accordingly (the lowest quality that you want all files to be at or higher).
You can mass rename (Organize) from the Series Editor.
How can i force check if there are higher qualities available?
As there are files with 720p quality when there are obviously 1080p qualities available.
Appreciate your help btw! (happy xmas! <3 )
(oh and btw, pulsar can’t download subtitles right?)
(pulsar is great btw, I freaking love it!)
