Better quality was not downloaded
Auto ignored because you have Automatically ignore deleted episodes enabled. Manually running it once or 10 times wouldn’t change the behavior.
Unfortunately the logs don’t show quite enough to say why it was rejected. I’ll add that to Trello so they’re a bit more detailed.
That has always been enabled and I never had any issues, or maybe I did. Maybe my whole setup in screwed up.
Anyway, I disabled that ignore deleted episode option.
Thanks for your help Markus. Much appreciated.
