I use Sonarr, SABnzbz and Plex. Previously I would download and the English subtitles would be there but lately it isn’t happening. Which program handles that?
I searched in the Plex forum and saw something about making sure the OpenSubtitles.org source is checked. I have done that and wonder if that will fix it or is there something in Sonarr I should be doing?
Sonarr does not copy any additional files atm, so the only way you are getting subs from sonarr is if they are embedded in the mkv. This only happens with some web-dls.
There are various way to run subtitle downloaders, i personally like autosub-bootstrapbill because it best caters to my dutch needs.
Plex opensubtitle plugin is another.
@subzero79 can you provide more help on subliminal. I’m interested on it to download from addicted but i was lost on the cli. What is the script that you are using ?
subliminal works fine although since i rename the shows to Showname 1x02 with no scene on the filename i get a few out of synch releases but i can manage.
Is there any plan on integrating automatic subtitles download from within sonarr ?
