so, i want to move a series’ location in sonarr.
is the best way to do this:
• move the series root folder in your file system from location-a to location-b
• update the location in sonarr?
is that it? am i overthinking this?
thanks!
thanks!
Yeah, thats it.
@markus101, are there best practices for moving multiple series en masse?
Not really, turning off Create Empty Series
folders (if its enabled) to prevent empty folders from being created if the series refresh task runs before you update the series, which would unlink all the files that you have (doubly important if the quality is not part of the filename).
