Banshee Eps ?
is anyone else getting Banshee Origins when trying to download the show Banshee?
it is a group called BATV it think that is releasing them?
I have so far, looks like KILLERS has been releasing the ones I have been getting.
yeah that is usually the group that has but setting up nzbdrone on a mates computer and set banshee episodes to download and it is giving The Banshee Origins instead of Banshee (2013)
this is the show i am trying to get it to download
http://www.tvrage.com/Banshee
and i have seen when doing a manual search the KILLERS releases but it still grabs the Banshee Origins Ones from BATV
googling banshee origins it appears to be some sort of Animated show
Sounds like the wrong show was added, I don’t even see results for Banshee origins when searching (nor would it match when doing a name comparison).
yeah it is weird the show appears to be the same and it has grabbed other episodes correct just for some reason episode 4 and 5
so what did is add that BATV to the restrictions box in settings and now that seems to have done the trick for now
Nzbdrone has been downloading the correct Banshee episodes for me. Doing a manual search only returns the correct episodes.
Suggest you try deleting Banshee from Nzbdrone series list and add it again.
Yeah, I agree with @malcontent really sounds like something is wrong for it.
just an update i tried this on my setup which is a complete from scratch and it grabbed the right KILLERS episode perhaps i might have to redo my friends install
yep no problem here grabbing the correct banshee
