Auto Delete Left Over Folders
How can I set sonarr to auto delete the left over folder (and files inside) after download, rename and move is complete?
If this isn’t possible then it is definitely a feature request!
It already does after importing from your download client as long as there aren’t any video files it failed to import, existing episode is equal or better quality or it failed for another reason.
Cool. Thing is some shows have sample video files in them which will cause sonarr to not delete the folder - am I correct with this?
No, sample files won’t stop the deletion, Sonarr will detect it as a sample and remove the folder still.
Thanks for the info. It actually appears that thumbs.db files are preventing deletion. Not a major problem as these normally dont appear in downloads. I was experiencing this problem when readding existing shows to sonarr.
