Sort of feature request, sort of bug, I’m not sure… it’s not breaking anything, it’s only visual.
As you can see, there’s plenty of space, but the Audio Info column wraps and uses two lines of text:
Example where the content of the column is shorter so it doesn’t use two lines:
Can the width be increased (dynamically)?
Version: 3.0.6.1277, although it’s probably been there for a while.
