Sonarr version: 2.0.0.5163
Mono version: 5.2.0
OS: FreeBSD
[Warn] ParsingService: Unable to parse episode info from path /mnt/news/Newsgroups/TV-SB/Arrested Development/Season 042018/Arrested.Development.S42018E01.Re.Capn.Bluth.720p.NF.WEB-DL.DD5.1.x264-NTb.mkv
[Warn] ParsingService: Unable to parse episode info from path /mnt/news/Newsgroups/TV-SB/Arrested Development/Season 042018/Arrested.Development.S42018E02.Three.Half.Men.720p.NF.WEB-DL.DD5.1.x264-NTb.mkv
[Warn] ParsingService: Unable to parse episode info from path /mnt/news/Newsgroups/TV-SB/Arrested Development/Season 042018/Arrested.Development.S42018E03.A.Couple-A.New.Starts.720p.NF.WEB-DL.DD5.1.x264-NTb.mkv
[Info] DiskScanService: Completed scanning disk for Arrested Development
[Info] ExistingMetadataImporter: Found 0 existing metadata files
[Info] ExistingSubtitleImporter: Found 0 existing subtitle files
[Info] ExistingOtherExtraImporter: Found 0 existing other extra files
[Info] ExistingExtraFileService: Found 0 extra files
Description of issue: Recently Arrested Development was re-edited and released on Netflix as Arrested Development Remix. In Sonarr it’s currently listed as Season 42018. I have used the Season information from Sonarr in order to try and get it detected when I press the Update Series/Scan Disk button. The issue that occurs that none of the episodes are detected on the disk. I believe my renaming of the series is according to what Sonarr should recognize.
The issue I think lies in the pattern recognition since this seems to be an exception to how seasons are normally named (see debug logs above). The files have the right permissions so it’s not an issue of being unable to access the files, they also play fine in VLC.
