Hi,
I am trying to install nzbdrone on a raspberrypi running raspian wheezy.
I have updated my sources.list to include
deb …apt.sonarr.tv/ master main
When I try to do
sudo apt-get -f install nzbdrone
I get the message
Reading package lists… Done
Building dependency tree
Reading state information… Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
nzbdrone : Depends: libmono-cil-dev (>= 3.10) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
When I then try to install libmono-cil-dev
libmono-cil-dev : Depends: libmono2.0-cil (= 3.10.0-0xamarin2) but it is not going to be installed
Depends: libmono-accessibility2.0-cil (= 3.10.0-0xamarin2) but it is not going to be installed
Depends: libmono-accessibility4.0-cil (= 3.10.0-0xamarin2) but it is not going to be installed
Depends: libmono-c5-1.1-cil (= 3.10.0-0xamarin2) but it is not going to be installed
Depends: libmono-cairo2.0-cil (= 3.10.0-0xamarin2) but it is not going to be installed
Depends: libmono-cairo4.0-cil (= 3.10.0-0xamarin2) but it is not going to be installed
Depends: libmono-cecil-private-cil (= 3.10.0-0xamarin2) but it is not going to be installed
Depends: libmono-codecontracts4.0-cil (= 3.10.0-0xamarin2) but it is not going to be installed
Depends: libmono-compilerservices-symbolwriter4.0-cil (= 3.10.0-0xamarin2) but it is not going to be installed
Depends: libmono-corlib2.0-cil (= 3.10.0-0xamarin2) but it is not going to be installed
Depends: libmono-corlib4.0-cil (= 3.10.0-0xamarin2) but it is not going to be installed
Depends: libmono-corlib4.5-cil (= 3.10.0-0xamarin2) but it is not going to be installed
Depends: libmono-cscompmgd0.0-cil (= 3.10.0-0xamarin2) but it is not going to be installed
Depends: libmono-cscompmgd8.0-cil (= 3.10.0-0xamarin2) but it is not going to be installed
Depends: libmono-csharp4.0c-cil (= 3.10.0-0xamarin2) but it is not going to be installed
When I check the apt-cache policy for libmono-cil-dev I see
libmono-cil-dev:
Installed: (none)
Candidate: 3.10.0-0xamarin2
Version table:
3.10.0-0xamarin2 0
500 apt.sonarr.tv/ master/main armhf Packages
3.10.0-0xamarin1 0
3.2.8+dfsg-4+rpi1 0
500 mirrordirector.raspbian.org/raspbian/ wheezy/main armhf Packages
This looks like the right candidate.
The problems seems to be that all these packages depend on mono-runtime, and that does not appear to be available in the sonarr repository. Is it possible to get this binary package from somewhere else?
Any suggestions greatly appreciated.
mono-runtime:
Installed: (none)
Candidate: 3.2.8+dfsg-4+rpi1
Version table:
3.2.8+dfsg-4+rpi1 0
