I’ve found the wiki article here and understand the API is at /api. However, how should the calls/requests be formatted? For example, if I wanted to pull episode information, how would I format the query? I see it’s seriesId, I also see I need to pass my api key somehow and what id is the series id based on, an id in the drone db or an id pulled from some service, or something else? http://localhost:8989/api?apikey=??? etc?
Thanks
