Is there an API for configuring tags? If not any possibility? I’m looking to have a script update a P2P tag periodically from a centralised location (probably github) with all the P2P groups.
Updating the tag or the a release restriction?
Anything that can be done in the UI can be done via the API (the UI uses the same API), but if it hasn’t been documented on the wiki, it could change without notice (though we try to avoid that whenever possible).
Updating a tag Must Contain I mean, to keep the current P2P groups there
As mentioned, if it can be done in the webui, it can be done in the API. If it is not documented you can use browser tools to see what calls are being made as you do it in the webui.
