Anime title with punctuation not downloading
I may have overlooked the option, but there seems to be no way to edit a search term for a show. Specifically I’m trying to download Rokujouma no Shinryakusha!?, but indexers have it listed either without the punctuation or without the ?, which causes NZBDrone to choke on it. Is it possible to have replacement terms to search (ie ō with ou/yo, or removing punctuation)?
Drone will use the alternate names supplied by thexem.de and its own alternate name list. Debug logs will show the search terms drone uses to search each indexer, have you verified exactly what its using?
Finished searching Fanzub for [Invaders of the Rokujouma!? : 03]. Found 0
Is what I see listed in the log(along with other indexers), however it didn’t exist on thexem.de. I’ve created it there and provided alternate names and am currently waiting for it to get published. Is there anything I’ll need to do after that or should it all be automatic? Thanks for the help!
That’s not the term it used to search, but the actual title (debug logs will show the URL). But since it wasn’t on thexem.de it is likely is just using the tvdb title.
Rokujouma works fine for me. Are you sure that you set the series as an anime and not as a standard series?
Edit: Ah, it looks like the name changed last week and TheXEM has not approved the draft that links the old title to the new one yet: http://thexem.de/xem/draft/1400
