Abarenbou Kishi!! Matsutarou
The File Of Young Kindaichi Returns
Added these and there are a few episodes missing from the series. Both trakt and tvdb list them correctly. Could this be a nzbdrone issue?
Thanks
Thanks
drone is incorrectly handling bad data coming from tvdb in this case, tvdb is missing the absolute episode numbers for 3 episodes in Abarenbou Kishi!! Matsutarou and all the absolute numbers for The File Of Young Kindaichi Returns, those issues will need to be correct before drone can grab or import those episodes, but the issue should be resolved on drone’s side in the next release.
Out of curiosity: how did you fix it? Do you fill in missing absolute numbers by handling the counting yourself? Or are you getting the data elsewhere?
@NMe drone was looking for distinct absolute episode numbers, so I made it only look for distinct over zero and take all the episodes with an absolute number of zero. It doesn’t fix the tvdb problem (lack of absolute number), but will at least show them in drone.
