Sonarr version (exact version): 2.0.0.5322 - Mar 25 2019 OS: Windows 10 Pro Debug logs: Description of issue:
Jojo’s Bizarre Adventure: Golden Wind was doing fine, until after S01E23 (136). The series is current on episode 33, but Sonarr doesn’t show any indexed episodes after E23.
Series type is marked as Anime, and no Tags are specified.
click on the blue The TVDB button’ish link, that will take you to the site where sonarr sources its data from. if the seasons/episodes are not there then it wont be in sonarr either.
you have the ability to create an account for that web site and add the seasons/episodes in yourself if you can source the data from their broadcaster
so long as the air dates are listed on the shows broadcast web site then the tvdb moderators shouldnt delete them after you add them
