Anime Episode Downloading Issues
Hi all,
I’ve added Lupin III and Voltes V and run into a couple of problems grabbing any episodes from them.
When set to either Standard or Daily, Automatic Search will find no results for any of them while Manual Search will always bring up the Detective Conan special to download, no matter which episode is being searched.
When set to Anime, the “Episode does not have an absolute number” error appears along side all episodes.
I checked on thexem for any listing of episodes and neither appeared only the “Woman called Fujiko Miine” entry is available. Am I out of luck here if the entry is on thexem?
I’ve just started with all of this, so I’ll be guessing it’s something I’ve missed (Hopefully!), I also did a search for similar problems but it didn’t look like at that time the problem had a solution.
Thanks in advance!
both Lupin II and Voltes V dont have absolute numbering on the tvdb., sonarr wont find anything for anime without absolute numbering
about the missing xem entrys you can ask on the xem irc channel
