When anime gets pulled from drone to nzbget thru animezb the file that gets downloaded is only 50-60 MB for some reason… i just tested it with sabnzb and it downloaded the file completely fine not sure whats going on there
Is the download size only 50-60MB or is drone importing the file before it is filly extracted?
What OS?
Are you using completed download handling?
yes using complete download handling… file extracts but some how only 50-60 MB download size was 600MB i did a double check to make sure it wasn’t a bad file by manually going to the size and pulling a nzb and pushing it to sab and it downloaded perfectly … did it again with download handling in sab and again it came out perfect… went back to nzbget and same scenario of 50-60 MB download
Can you test it with nzbget manually (without drone), if it’s still only 50-60mb it must be nzbget.
