thexem.de or thetvdb.com keeps screwing with the mappings for Ancient Aliens:
Notice that Season 7 (top) and Season 6 have the same episodes. First 5, and last 5, respectively.
Anyone know how to fix this annoyance?
LJ
LJ
thexem.de doesn’t change the way the data is displayed in Sonarr, just changes the numbering when grabbing/searching/importing.
That means the data is coming from thetvdb. You can fix it there, just make sure you fix it correctly (if its wrong it will be re-added and the series locked), so follow the network’s lead.
@markus101 - Thanks!
Anyone here know how to fix and/or double-check the naming? See ^ as it appears to be dorked to me!
LJ
For anyone monitoring this show… FYI:
http://forums.thetvdb.com/viewtopic.php?f=7&t=21761
Hopefully changed soon!
LJ
I’m impatient … anyone know a mod/admin that would be able to fix this? I don’t believe I can delete invalid episodes…
See ^ link.
LJ
