American Dad - can't get it to work
I’ve added the 11th season (indexers show it as 10th) and ND can’t find them. I’ve read that this might be an issue with “mapping from thexem.de weren’t available for the first search”. So I restarted ND and updated the show info - still nothing.
Any advice?
Same issue here…
I checked on thexem.de manually and I don’t think they’ve added Season 11 yet as this shows as of 9-15-2014:
http://thexem.de/xem/show/779
LJ
Is the mapping live on thexem.de or is it still in draft? Sounds like there is a lot of confusion about this one and it may be a double episode or it may not. Until that settles its going to be a manual grab.
It was a single episode (1) on thetvdb for a couple of hours before it got fixed to 1&2.
but yeah, thexem still needs an update. doesn’t even have a draft yet.
xelra updated thexem for us. should be handled properly after a series refresh.
Yeap. Restarted ND & updated the series - everything works.
Many thanks!
