I was just wondering if it’s possible to have a filter setup that blocks webrips for the bulk of my shows, but allows them for Netflix?
Thanks!
~Spritz
EDIT - It appears I can do this with Tags, to a degree. Is it possible to either assign tags to a quality profile, or have a default tag (eg - no webrips) that can get overridden by another tag (eg - webrips are a-ok).
No, tags all tie back to series, this is to avoid really complicated scenarios where you’re not sure how the tag will be applied.
Not currently, no way to set a default tag (or set of tags), though that might be useful when we support setting tags when the series is added and tags are all applied, so one requiring it and another not allowing it both apply and it wouldn’t be allowed.
