Air Crash Investigation Incorrectly Matched
I seem to be getting some very strange matches for Air Craft Investigation:
http://picpaste.com/26f765cc36ee8eff5a6c7b72e7ca57d5.JPG
http://picpaste.com/4faea4947fa780da2ca5071b59de93ef.JPG
http://picpaste.com/796a7aeceb6a699417662d8b31cda143.JPG
http://picpaste.com/6f142be30cb6bb657b9e1e207c55320a.JPG
Any suggestions as to why this could be?
No, your images don’t load.
Doe they not open if you click the link? I can’t find a way to embed images in the post?
Yeah, obviously I clicked on them, the site wouldn’t load. It loaded now.
I can’t reproduce this behaviour; without trace logs there isn’t anything else I can check.
Guessing that site is suspect then, first time using it, my apologies about that. I unfortunately only have the normal logs and I have looked through them, there is nothing that I can spot that would cause this strange behaviour, only thing I could spot is the SceneMappingService kicked off an update and the RssSyncService started a RSS Sync while the ParsingService was still busy, however I doubt it’s that causing the problems (Happy to send them along if they can help). Would I have to run NzbDrone from the console if I wanted to enable the trace logs?
I have uploaded the detailed trace logs to http://sdrv.ms/1bpFUZ1 after managing to reproduce the problem. It matched “Air Crash Investigation - Mayday - 2x03 - Killing Machine (Hijacked)” to “Food.And.Drink.2013.S02E03.HDTV.x264-C4TV” as can be seen in the logs. I see when the search happens NZB MEgasearcH is returning 600 items and very few of them are matching “Air Crash Investigation - Mayday - 2x03 - Killing Machine (Hijacked)” how ever I would assume NzbDrone will not just blindly accept results returned as being correct.
Usually these things come from a mismatched tvrage id, but ACI doesn’t have one from trakt, so it relied purely on name matching, which is far from a match. Asked trakt to add the tvrage id, which will making searching more reliable: http://support.trakt.tv/forums/188762-general/suggestions/5510113-tvrage-id-air-crash-investigation-mayday
Those two jobs wouldn’t run in parallel (they may run immediately after the other). Trace logging can be enabled on the General Settings page.
Thanks.
