Version 3.0.9.1549
Package Version 3.0.9 by Team Sonarr
Mono Version 6.8.0.105
AppData directory /var/lib/sonarr
ubuntu 22.04
Problem with addresses. I have not sent the entire log because this is the problem. If you want it I can send it.
I got a pile of these on Nov 24.
Nov 24 2022 DownloadedEpisodesImportService Import failed, path does not exist or is not accessible by Sonarr: /home/(removed)/Video/tv/Andor.S01E12.1080p.WEB.H264-GGEZ[TGx]/. Ensure the path exists and the user running Sonarr has the correct permissions to access this file/folder
They all say the same problem with the same file. I checked address in the file and it was:
“/media/greg/data/TV/Andor” which is correct
Then there is where to find a download which is the home directory, the address of that is /home/greg/" and the location of the file is supposed to be “/home/greg/Video/video/tv” .
Sometimes the downloaded show has a longer title than the simple “Andor” which may be the problem although I get this on others as well.
Its strange. This is the only show that is having a problem. When I know it happens I simply goto the location it says isn’t and transfer it to the library.
This isn’t critical and I can live with it but was just wondering.
Thank you…
