I come from Sickrage and now testing Sonarr, it will be appreciated to be able to add cpasbien.io as indexer for us french people and add the possibility to download the description of the series and episode in french like in Sickrage !
Sonarr didnèt found 4 of my series Im searching why !
BTW it was easy and install the UI is awesome ! TY !
How about adding ability to add custom indexer? I would like ExtraTorrent added as a fallback for Kickass. As from time to time Kickass does faces downtime or url change.
You can add a custom RSS feed for Torrents, or look at Jackett for support for other sites, unless the site has a proper API (and most don’t), support will not be added directly to Sonarr.
