I have read others with problems with the activity queue but this is strange. Apparently this comes from the downloader (sabnzbd?) This is for a season 2 episodes. The problem is that I have that season’s episodes on my data drive yet these keep popping up. When I goto season pass and check it tells me that I have 13/13 episodes yet it keeps on wanting them anyway.
I have, incidentally, just reinstalled. The logfile I have included is the one I copied out of my terminal which was sent, to that terminal, when I ran the program with:
mono --debug /opt/NzbDrone/NzbDrone.exe
To keep the program running I couldn’t exit out of the terminal.
Here is a current debug file: https://pastebin.com/sxbn9XXF
Have a screenshot? You seem to be referring to something you’re seeing, but we can’t see it…
Activity: Queue doesn’t care if the files are already on disk, it shows everything that hasn’t been imported yet. If you re-installed and the Sonarr database was started from scratch the history in Sonarr wouldn’t know what a previous instance imported and would want to import the files again.
If that’s the case, you’ll need to do one of the following:
Remove the history from SAB
Change the category Sonarr is using in SAB
Wait for more history items to be added in the category Sonarr is using (Sonarr only fetches the last 30 items)
I have now removed the history from sab. That may do the trick. I am concerned about all the errors in my log file about not finding stuff on /home/greg/video/tv but I think that should be /mnt/data/tv. I have no idea where its getting that address from)
I also have been unable to set the media management page (trying to tell it to ignore removed files which may help in this) although I can press the save and it seems to work. Then I do other stuff and, eventually, all changes get removed. I have posted, I think, my browser log as I don’t understand what its saying. https://pastebin.com/7LDhUgdt
I did most of what you suggested and that seemed to stop the wanted and the queue thing has also calmed down… Still working on the save the media thing. I know its possible as I have done it but, now… I will keep on working on it. I will also try the browser without any addons to see if that makes a difference.
