Sonarr version: 3.0.0.348
OS: Windows 10
Debug logs: https://hastebin.com/xidageseqi.rb
Description of issue: Suddenly today, after adding a larger than normal amount of downloads, the activity queue on both Sonarr and Radarr has stopped working. I am using Transmission as my download client, and I’m assuming since both programs are having the same issue, then Transmission is what’s gone wrong. But the only setting I’ve changed on Transmission is the amount of active downloads - from 45 to 10. Transmission will still download everything to completion and seed it, but Sonarr is not picking up Transmission as a download client, cannot see the downloads after requesting them, and is unable to move finished downloads into the appropriate folders. No idea what’s caused this.
You’re using an old version of the v3 beta, before anything else, upgrade.
If you’re still having issues, enable trace logging and restart Sonarr, after a couple minutes grab the trace logs, that should show the initial communication with Transmission.
I managed to find a fix by replacing Transmission entirely with qBittorrent, and activity is now working again. Thank you for alerting me to the old version though!
