Is there any way to have an image load, behind forms auth, using the API key as a URL parameter?
For example - http://localhost:8989/MediaCover/61/poster.jpg?apikey=123456
Also, just tested and can’t seem to get it working w/ API key in request header either.
I believe it’s:
http://localhost:8989/api/MediaCover/61/poster.jpg?apikey=123456
Yeap, that did it! Thanks for the quick response @markus101!
system
Closed
4
