Sonarr version (exact version): 3.0.0.192
Mono version (if Sonarr is not running on Windows): 5.12.0.226
OS: Linux / ubuntu
The release with name Tatort.E1060.Schlangengrube.GERMAN.720p.HDTV.x264-ACED-Rakuv'
is being parsed as Tatort - 106
not 1060
(see logs below)
I’ve marked the Tatort show as Anime
type because all releases of Tatort use the absolute number.
This is also happening in v2, I upgraded to v3 specifically to see if it had been fixed.
Screenshot: https://imgur.com/a/O7XSmHh.png
18-6-13 17:49:02.9|Debug|Parser|Parsing string 'Tatort.E1060.Schlangengrube.GERMAN.720p.HDTV.x264-ACED-Rakuv'
18-6-13 17:49:02.9|Debug|Parser|Episode Parsed. Tatort - 106
18-6-13 17:49:02.9|Debug|Parser|Language parsed: German
18-6-13 17:49:02.9|Debug|QualityParser|Trying to parse quality for Tatort.E1060.Schlangengrube.GERMAN.720p.HDTV.x264-ACED-Rakuv
18-6-13 17:49:02.9|Debug|Parser|Quality parsed: HDTV-720p v1
18-6-13 17:49:02.9|Debug|Parser|Release Group parsed: Rakuv
18-6-13 17:49:02.9|Debug|ParsingService|Using absolute episode number 106 for: Tatort - TVDB: 1979x12
18-6-13 17:49:02.9|Debug|AcceptableSizeSpecification|Beginning size check for: Tatort.E1060.Schlangengrube.GERMAN.720p.HDTV.x264-ACED-Rakuv
18-6-13 17:49:02.9|Debug|AcceptableSizeSpecification|Item: Tatort.E1060.Schlangengrube.GERMAN.720p.HDTV.x264-ACED-Rakuv, meets size constraints.
18-6-13 17:49:02.9|Debug|MaximumSizeSpecification|Maximum size is not set.
18-6-13 17:49:02.9|Debug|LanguageSpecification|Checking if report meets language requirements. German
18-6-13 17:49:02.9|Debug|QueueSpecification|Checking if existing release in queue meets cutoff. Queued quality is: HDTV-720p v1 - German
18-6-13 17:49:02.9|Debug|QueueSpecification|Checking if release is higher quality than queued release. Queued quality is: HDTV-720p v1 - German
18-6-13 17:49:02.9|Debug|ReleaseRestrictionsSpecification|Checking if release meets restrictions: Tatort.E1060.Schlangengrube.GERMAN.720p.HDTV.x264-ACED-Rakuv
18-6-13 17:49:02.9|Debug|ReleaseRestrictionsSpecification|[Tatort.E1060.Schlangengrube.GERMAN.720p.HDTV.x264-ACED-Rakuv] No restrictions apply, allowing
18-6-13 17:49:02.9|Debug|QualityAllowedByProfileSpecification|Checking if report meets quality requirements. HDTV-720p v1
18-6-13 17:49:02.9|Debug|MinimumAgeSpecification|Minimum age is not set.
18-6-13 17:49:02.9|Debug|RetentionSpecification|Checking if report meets retention requirements. 3
18-6-13 17:49:02.9|Debug|EpisodeRequestedSpecification|Release rejected since the episode wasn't requested: Tatort - 106 HDTV-720p v1
18-6-13 17:49:02.9|Debug|SeriesSpecification|Checking if series matches searched series
18-6-13 17:49:02.9|Debug|DelaySpecification|Ignoring delay for user invoked search
18-6-13 17:49:02.9|Debug|HistorySpecification|Skipping history check during search
18-6-13 17:49:02.9|Debug|MonitoredEpisodeSpecification|Skipping monitored check during search
18-6-13 17:49:02.9|Debug|DownloadDecisionMaker|Release rejected for the following reasons: [Permanent] Quality for release in queue is of equal or higher preference: HDTV-720p v1 - German, [Permanent] Episode wasn't requested: 1979x12
