Sonarr version (exact version): 2.0.0.5153
OS: Win10 Pro 64bit
Debug logs: https://drive.google.com/open?id=1j8dab78LNSU3sjiherLFbA-BWAOvAgsF
Hello, I have been using both Radarr and Sonarr for about 2 years. The machine it’s hosted on is remote, and is on a VM.
About a month ago, I started having issues accessing Sonarr via local IP. I can use the external IP and port, both locally and remotely, and Sonarr loads and logs in fine. However, if I remote into the VM, Sonarr will load the log in page, but will not log in.
Now here’s part 2 of this strange issue. The same exact thing with Radarr started the same day, about a month ago, however, today I can ONLY access Radarr via local IP when on the VM. External IP will not load the page at all. Just hangs. This is true if I use my URLs or direct IP address with port. I’ll share a txt doc with the URLs I use via Google Drive, so I can remove them after this is resolved for people to use and test.
Radarr Logs: https://drive.google.com/open?id=1fPRsuRBhy5WmEQBdEoJH5KTGiBA-NB6z
Nothing changed except I restarted the router that had been online for about 3 weeks. Restarted all hardware with no change. Nothing in any of the OS’s has changed either.
Thanks for the help!
