Sonarr version (exact version): 4.0.9.2244
OS: Docker
Hello,
I am French, and I use Radarr on my Docker installation. I used Recyclarr to create my custom profiles, and it works really well. The only downside is that if I have a series that’s not in the correct language, and even though there is a version with the right language and a better score, if the episode is in the same quality, it won’t download it. Is there a way to still trigger the upgrade?
