A few unrelated questions
I have a few questions that I wanted to see if someone could help with.
  1. Sonarr has every Orange is the New Black episode set to air this Friday. Is there a way to fix that so it’s not trying to download all the episodes and use up all my indexer API requests?
  1. It also has two episodes of Tanked listed for 5/29, but they are both listed as S09E01. TheTVdb only has one listed. Is there a way to get rid of the second?
  1. Some of my shows that I had to download using uTorrent, have an unusual red cloud in the green square. It says “Download Failed” when I hover over the icon. I have the episode now and Sonarr sees it, so is there a way to get rid of the red cloud?
  1. I’m also having terrible issues getting the show Pawn Stars. I’ve posted with my indexer and haven’t received a resolution. Does anyone know if they stopped being released or if I have an issue with my indexer? Things worked up thru 2015x21 which was the last episode I was able to find.
Thanks!
  1. They all release on the same day because its Netlfix, but Sonarr isn’t wasting API calls on them: https://github.com/Sonarr/Sonarr/wiki/FAQ
  2. Refresh the series in Sonarr, must have been bad data there.
  3. Depends on why it failed, check Activity: Queue
  4. Pawn Stars alternate numbering is handled via thexem.de but it is up to date: http://thexem.de/xem/show/1759 I’m able to find 2015x22 as 12x22
  1. Perfect. I hadn’t stumbled on that FAQ when I was looking for an answer.
  2. I hit the “Update series info and scan disks”. The offending entry is still shown in the calendar.
  3. After adding a new indexer (because my old on sucked) and downloading a higher quality episode of both shows to replace the crappy torrent, the red cloud disappeared.
  4. Thanks. My new indexer found almost all the shows, so once again, it was an issue with my indexer.
On other question if I may. I see that the max file size is 12.58GB under the quality settings. Is there a way to exceed that cap? I’m finding some of my shows (Game of Thrones, Penny Dreadful) are being released with Web-DL files above 15GB. I’m not that far along in my seasons to see if the picture quality is fantastic at that size, but was just curious.
Thanks again!
2. If you remove the series do both disappear?
5. Not sure if its in the master release yet, but setting to max size will eventually be treated as unlimited, setting it to 0 currently will make it unlimited though.
For some reason, the second Tanked episode magically disappeared the other day.
Will the max size be expanded past the 12.58GB? I don’t want it to start downloading 100GB TV shows. :smile:
We’re not increasing the size at this time, its now unlimited when maxed out.
Thanks markus for your help.
Any idea why this show is listed as still downloading? The file has been downloaded and cataloged by SAB already.
cataloged by SAB ?
put your mouse over the orange box to the left of the word ‘Stike Back’ and see what the message says.
