576p quality mismatch
Thank you for a great piece of software!
My question is rather simple, I would like this release to NOT be tagged as Bluray-720p: Hannibal.S01E05.576p.BluRay.DD5.1.x264-HiSD
Is this a reasonable request? Or would you prefer that 576p match as 720p to keep configuration easier?
Currently it sees the Bluray and no 1080p so it treats it as BR 720p. Hadn’t seen that resolution before, looks like it would be closest to DVD (its an SD resolution), does that make sense?
Yes, if having to choose from the currently available quality tags, I would much rather like this release to be tagged as DVD.
It’s a tricky thing to accurately match release names to quality tags without making the list of available tags infinitely long. I do however miss a separate tag for BDRips since I much prefer them over DVDRips. In my mind the release I mentioned is best suited for a BDRip tag.
Use release restrictions to prevent DVDrips from being grabbed, we have no plans to change the qualities.
