Latest Sonarr, Win x64, torrents via Jackett & NZBs via NZBHydra2.
On nzbgeek, it is categorized as TV > HD. 3.5GB.
A manual search from NZBHydra2 finds it in “TV HD” (Newznab category 5040).
Jackett results are correctly parsed out.
The.Island.with.Bear.Grylls.S05E06.1080i.HDTV.DD2.0.H.264-NTb
Considering that the title contains 264, shouldn’t that indicate that it is not RAW?
I assume its the 1080i that’s making Sonarr determine that it is RAW?
18-5-2 06:15:49.9|Debug|NzbSearchService|Total of 2 reports were found for [The Island with Bear Grylls : S05E06] from 2 indexers
18-5-2 06:15:49.9|Info|DownloadDecisionMaker|Processing 2 releases
18-5-2 06:15:49.9|Debug|DownloadDecisionMaker|Processing release ' / 3 (1-5 ) / The Island with Bear Grylls [2016, WEBRip]' from 'Jackett'
18-5-2 06:15:49.9|Debug|Parser|Parsing string ' / 3 (1-5 ) / The Island with Bear Grylls [2016, WEBRip]'
18-5-2 06:15:49.9|Debug|Parser|Unable to parse / 3 (1-5 ) / The Island with Bear Grylls [2016, WEBRip]
18-5-2 06:15:50.0|Debug|Parser|Parsing string ' / 3 (1-5 ) / The Island with Bear Grylls [2016, WEBRip]'
18-5-2 06:15:50.0|Debug|Parser|Unable to parse / 3 (1-5 ) / The Island with Bear Grylls [2016, WEBRip]
18-5-2 06:15:50.0|Debug|ParsingService|No matching series / 3 (1-5 ) / The Island with Bear Grylls [2016, WEBRip]
18-5-2 06:15:50.0|Debug|DownloadDecisionMaker|Processing release 'The.Island.with.Bear.Grylls.S05E06.1080i.HDTV.DD2.0.H.264-NTb' from 'NZBHydra2'
18-5-2 06:15:50.0|Debug|Parser|Parsing string 'The.Island.with.Bear.Grylls.S05E06.1080i.HDTV.DD2.0.H.264-NTb'
18-5-2 06:15:50.0|Debug|Parser|Episode Parsed. The Island with Bear Grylls - S05E06
18-5-2 06:15:50.0|Debug|Parser|Language parsed: English
18-5-2 06:15:50.0|Debug|QualityParser|Trying to parse quality for The.Island.with.Bear.Grylls.S05E06.1080i.HDTV.DD2.0.H.264-NTb
18-5-2 06:15:50.0|Debug|Parser|Quality parsed: Raw-HD v1
18-5-2 06:15:50.0|Debug|Parser|Release Group parsed: NTb
18-5-2 06:15:50.0|Debug|AcceptableSizeSpecification|Beginning size check for: The.Island.with.Bear.Grylls.S05E06.1080i.HDTV.DD2.0.H.264-NTb
18-5-2 06:15:50.0|Debug|AcceptableSizeSpecification|Max size is unlimited - skipping check.
18-5-2 06:15:50.0|Debug|AcceptableSizeSpecification|Item: The.Island.with.Bear.Grylls.S05E06.1080i.HDTV.DD2.0.H.264-NTb, meets size constraints.
18-5-2 06:15:50.0|Debug|MaximumSizeSpecification|Maximum size is not set.
18-5-2 06:15:50.0|Debug|LanguageSpecification|Checking if report meets language requirements. English
18-5-2 06:15:50.0|Debug|ReleaseRestrictionsSpecification|Checking if release meets restrictions: The.Island.with.Bear.Grylls.S05E06.1080i.HDTV.DD2.0.H.264-NTb
18-5-2 06:15:50.0|Debug|ReleaseRestrictionsSpecification|[The.Island.with.Bear.Grylls.S05E06.1080i.HDTV.DD2.0.H.264-NTb] No restrictions apply, allowing
18-5-2 06:15:50.0|Debug|QualityAllowedByProfileSpecification|Checking if report meets quality requirements. Raw-HD v1
18-5-2 06:15:50.0|Debug|QualityAllowedByProfileSpecification|Quality Raw-HD v1 rejected by Series' quality profile
18-5-2 06:15:50.0|Debug|MinimumAgeSpecification|Checking if report meets minimum age requirements. 621.2
18-5-2 06:15:50.0|Debug|MinimumAgeSpecification|Release is 621.2 minutes old, greater than minimum age of 5 minutes
18-5-2 06:15:50.1|Debug|RetentionSpecification|Checking if report meets retention requirements. 0
18-5-2 06:15:50.1|Debug|SeriesSpecification|Checking if series matches searched series
18-5-2 06:15:50.1|Debug|DelaySpecification|Ignoring delay for user invoked search
18-5-2 06:15:50.1|Debug|HistorySpecification|Skipping history check during search
18-5-2 06:15:50.1|Debug|MonitoredEpisodeSpecification|Skipping monitored check during search
18-5-2 06:15:50.1|Debug|DownloadDecisionMaker|Release rejected for the following reasons: [Permanent] Raw-HD is not wanted in profile
