1 Episode - 2 parts/CD
Sonarr version (exact version): 2.0.0.5228
OS: Windowws 10
Description of issue: I have a “special” episode from 'battle of the Planets (The Movie) where it has 2 parts (CD 1 and CD 2).
When I import it, both manually and automatically, it only poulls one of the parts, and leaves the other.
Can someone tell me the naming convention I should be using :slight_smile:
E.g.
S00E03A - Battle Of The Planets - CD 1
S00E03B - Battle Of The Planets - CD 2
I have checked the Wiki - I couldn’t see anything about naming rules or conventions
Any help would be greatly appreciated
Sonarr only supports one file per episode, they’ll need to be joined for Sonarr to see it as one.
Thinks Markus
Can you suggest any packages I can use to join/merge the parts ?
mkvmerge, but I’m sure there are lots of others.
