Manual Import Problems
Hey,
I’ve been having some minor problems with the manual import for Castle (2009). I’ve found that episodes with numbers in the titles don’t import correctly. For example http://thetvdb.com/?tab=episode&seriesid=83462&seasonid=524533&id=4770164&lid=7
The filename that’s being imported is: Castle (2009) - [06x16] - Room 147.mp4
When I attempt to manually import it I get:
Obviously I can manually override the requisite properties however I don’t understand why it’s confused when parsing. I did find that until I renamed all the files, from Castle 2009 to Castle (2009), none of the episodes would import.
Thanks
The cause is the square brackets around the season and episode numbers which has a lower priority than parsing the season and episode number from a 3 or 4 digit number, which is part of the episode title.
I made a change that will correct this in the next release.
Ah! That explains it. Thanks for the quick response!
